TwinTurbo.NET: Nissan 300ZX forum - I'm still not sure there's an air leak worth worrying about
Subject I'm still not sure there's an air leak worth worrying about
Posted by Zarcasm(Hfd, CT) on October 12, 2009 at 10:24 PM
  This message has been viewed 496 times.
In Reply To IMHO, your EGR valve should not leak at 1 psi. posted by canyoncarver on October 12, 2009 at 07:57 PM
Message Here's the current score:
Vacuum gauge test indicates normal-high vacuum at idle --no air leaks.
FSM PCV test indicates engine rpm remains fixed --no air leaks.
Pressurizing the plenum I can't hold more than 1 psi, most significant air leak comes from the stem of the EGR valve --some leak.
Thanks for the carb cleaner (or better yet starting fluid) recommendation.
