TwinTurbo.NET: Nissan 300ZX forum - IMHO, your EGR valve should not leak at 1 psi.
Subject IMHO, your EGR valve should not leak at 1 psi.
Posted by canyoncarver on October 12, 2009 at 7:57 PM
  This message has been viewed 516 times.
In Reply To Is the EGR valve stem supposed to leak?? posted by Zarcasm(Hfd, CT) on October 09, 2009 at 11:59 PM
Message I can understand some leakage when boosting but you shouldn't be leaking anything at low pressure. Leakage at that low of pressure signifies a vacuum leak. With the motor idling, have you tried spraying carb cleaner around the valve to see if your idle speed changes?
