TwinTurbo.NET: Nissan 300ZX forum - Actuating vacuum is not the problem
Subject Actuating vacuum is not the problem
Posted by Zarcasm(Hfd, CT) on October 10, 2009 at 2:42 PM
  This message has been viewed 495 times.
In Reply To Check the EGR with vacuum since that is the signal that >>> posted by ZUL8TR on October 10, 2009 at 07:53 AM
Message Probably the EGR works ok. I'll check diaphram operation later today. My concern is with intake air leaks.
My test may be inconclusive but an air leak around the EGR valve stem impacts idle operation directly since it provides UNMETERED air into the intake plenum. If it's very little then it can be compensated for with the idle adjustment on the Idle Air Adjustment (IAA) unit with virtually no impact on the a/f ratio. If it's a lot then then the MAF sensor senses too low a flow value at high vacuums around idle the engine will run lean. On a NA the proportion of such unmetered air drops off as the throttle is opened and plenum vacuum falls off. These are the symptoms my car is exhibiting but since the EGR valve seems not to be hermetically sealed by design the question is how much is too much? Help.
