TwinTurbo.NET: Nissan 300ZX forum - Check the EGR with vacuum since that is the signal that >>>
Subject Check the EGR with vacuum since that is the signal that >>>
Posted by ZUL8TR on October 10, 2009 at 7:53 AM
  This message has been viewed 590 times.
In Reply To Is the EGR valve stem supposed to leak?? posted by Zarcasm(Hfd, CT) on October 09, 2009 at 11:59 PM
Message it operates with. If vacuum supplied the diaphram should hold and not loose vacuum. This is a simple check to do. Since the NA plenum operates under vacuum when engine is running to at most atmospheric pressure when under hard acceleration,the pressure test you describe appears non conclusive for the EGR to me.
ZUL8TR in Orlando,FL
