TwinTurbo.NET: Nissan 300ZX forum - Wiring for the Sensors per manufacturer
Subject Wiring for the Sensors per manufacturer
Posted by -Grimm- on July 03, 2009 at 3:05 PM
  This message has been viewed 478 times.
In Reply To Re: Viper 5901 Alarm/Remote Start Installation Procedure posted by -Grimm- on July 01, 2009 at 11:09 PM
Message Using diodes is a good idea, i no longer get false alarms from the sensors.
Hooking them all to constant power yields a much more accurate and stronger sensor, before the zone on the radar sensor was erratic, now its constant and strong.
I hooked the red/black wires from only my shock sensor to the red/black of the extra plug.
All other sensors red/black when to constant power and constant ground respectively.
Tilt sensor has an orange instead of a black, hook this to ground when armed. The reason is so the tilt sensor can set a baseline everytime you park.
All the blue wires from the sensors go to the ANODE side of the diode. Connect all the cathode sides to the control unit blue wire.
Same deal for the green wires.
DO NOT connect any sensors besides the tilt sensor to the ground when armed. This will cause the sensors to set the alarm off every time it is armed.
