TwinTurbo.NET: Nissan 300ZX forum - Help please loud clunk
Subject Help please loud clunk
Posted by Evan(CA) on June 27, 2009 at 10:49 PM
  This message has been viewed 148 times.
Message I turn onto the road and floored it in first on low boost 12psi at about 6k rpm I heard a loud clunk and it felt like something was hitting the ground stopping the car from moving. I pulled over and looked underneath and everything looked normal but it's hard to see under a lowered z .Anyways the car runs fine and revs normal in neutral. As well as in gear as long as the clutch is depressed. If you let the clutch out in any gear you roll roughly 6" and then stop. Did my clutch explode? Snapped driveshaft? I had heard an odd whine days prior but thought it was due to my new stereo install which I have since fixed. Another thing to mention is in neutral it will roll smoothly, only in gear will it get stuck. The car is undriveable and was towed home.
Looks like the Z will spend Sunday on jack stands any tips on what to look for first?
