TwinTurbo.NET: Nissan 300ZX forum - In addition; I tested the voltage using a multimeter at both
Subject In addition; I tested the voltage using a multimeter at both
Posted by ZEVAN (Ca) on June 27, 2009 at 4:14 PM
  This message has been viewed 118 times.
In Reply To Dual Maf question... posted by ZEVAN (Ca) on June 27, 2009 at 02:09 PM
Message Inputs and at the output. The voltage I measured at the inputs matched
what the neo was saying however I measured 1.45v at the output which
is closer to what I was expecting but not what the neo is saying.
I went for a short drive and under load I found that the two mafs
outputted almost identicle voltages. Now I suspect the mafs are both
ok...driver side maf must be pulling more air at idle due to the idle air
control.
I don't plan on driving it again until I get a wideband because I fear the
neo may cause it to run lean with those voltage levels.
If anyone has this setup i'd be very interested to know if your output
voltage is actually the sum of the two input voltages.
Formerly: Evan3zx(ca)
Xbox live GT: kidding Me
1991 CRP TT
1993 Pearl White NA
