TwinTurbo.NET: Nissan 300ZX forum - amp on/off signal?
amp on/off signal?
gt300zxtt
on June 16, 2009 at 11:25 AM
Car won't start after stereo install
posted by BigTDogg (MA)
on June 16, 2009 at 09:56 AM
but, real suspect would be the amp draining current when going to start. so the real suspect would be what source are you using for amp turn on/off signal. is the starter the only device getting power when starting or is the amp on as well?
09:56:40 06/16/09
OK, scratch that. It started fine, but died as I was typing
10:17:40 06/16/09
amp on/off signal? -
gt300zxtt
11:25:58 06/16/09
Not switched 12V, the blue line from the Alpine. (n/m)
11:44:18 06/16/09
Some things to consider
NytWolf
16:38:13 06/16/09
Thanks for the reply, some answers
20:32:25 06/16/09
have you tried a jump start
gt300zxtt
22:15:25 06/16/09
The ring breaking happened on my old Z, I know exactly
08:40:50 06/17/09
Did you use the stock rear speaker enclosures w/6.5" ?
Nick(CT)
20:05:19 06/16/09
I can diagram it up, heck I can even install it
20:46:44 06/16/09
Thanks! This is a start. I'll email you when I start
Nick(CT)
21:08:07 06/16/09
OK, so I've completely disconnected the audio system
11:03:23 06/17/09
So it's not the sound system
NytWolf
11:58:43 06/17/09
It might not be the stereo, but it's something else I did
08:38:46 06/18/09
You installed a car alarm? Some of the alarms with fancy
treese88
09:41:38 06/18/09
By shizza I mean disconnected the brain, stuffed wires
10:53:49 06/18/09
Right, so it wasn't the stereo system, it was the boomslang
11:02:05 06/18/09
Glad you found the problem. Hopefully that's the only thing. (n/m)
NytWolf
01:00:56 06/19/09
Yeah, that's definitely it. It was the source of my
07:33:39 06/19/09
