TwinTurbo.NET: Nissan 300ZX forum - Re: Blown turbo seals OR just too much oil?
Subject Re: Blown turbo seals OR just too much oil?
Posted by Stpdfast Z on June 11, 2009 at 7:23 PM
  This message has been viewed 357 times.
In Reply To Blown turbo seals OR just too much oil? posted by blackomega on June 11, 2009 at 01:47 PM
Message This is a long shot but it's what was wrong with my TT that was smoking like the turbo seals had gone bad. I ended up with a hole in the pressure side of my fuel rail rubber line. It caused my Z to run lean under hard acceleration and as the hole increased in size to smoke even at idle. So check your fuel system and pressure coming from your fuel pump. A bad fuel pump, clogged fuel filter, dirty injectors or a leak in your fuel system can all cause you to run lean.
