TwinTurbo.NET: Nissan 300ZX forum - For starter's, on these cars the PCV valve threads into the
Subject For starter's, on these cars the PCV valve threads into the
Posted by MixManMash on June 09, 2009 at 2:58 PM
  This message has been viewed 380 times.
In Reply To Any chance PCV valves are bad, installed incorrectly, etc? posted by blackomega on June 09, 2009 at 02:47 PM
Message underside of the plenum. Only one side has threads so it's impossible to install them incorrectly.
It's pretty easy to diagnose a bad PCV if you get it out. Basically the valve should open and close freely.
If the PCV valve is stuck open, you may notice seals & gaskets leaking from excessive pressure. First thing though, the dipstick would probably blow out. However, the dipstick blowing out can also be caused by low compression.
