TwinTurbo.NET: Nissan 300ZX forum - Yeah. I had the same symptoms when I popped #6.
MixManMash
on June 09, 2009 at 2:33 PM
The smoke gradually stops.
posted by blackomega
on June 09, 2009 at 02:19 PM
I even found oil in my IC piping but all the oil was from blow by and it go everywhere. What a mess!
Boost -> Let off -> SMOKE!
blackomega
11:38:15 06/09/09
Do a compression test. This sounds like blow-by to me.
MixManMash
11:52:08 06/09/09
have you checked for oil in your IC piping?
aliaZ
11:59:35 06/09/09
18.8 PSI on 93 octane
blackomega
12:32:32 06/09/09
18.8 PSI on 93 octane! I would vote that you had some
MixManMash
14:06:22 06/09/09
blackomega
14:19:09 06/09/09
Yeah. I had the same symptoms when I popped #6. -
MixManMash
14:33:00 06/09/09
2nd. (n/m)
JustinSCZ32
17:31:13 06/09/09
2nd. That is a lot of boost on 93... (n/m)
ThunderZ
18:46:59 06/09/09
The post tile says bad turbo seal to me.
Woody75 (Denver)
13:28:38 06/09/09
Does that mean the turbo is bad??
blackomega
13:32:21 06/09/09
How do you know the turbo is good?
Woody75 (Denver)
14:05:49 06/09/09
Re: How do you know the turbo is good?
blackomega
14:16:05 06/09/09
Exhaust hooks to the turbos.
Woody75 (Denver)
14:33:48 06/09/09
Re: Exhaust hooks to the turbos.
blackomega
14:38:15 06/09/09
I found when #6 went, oil was being sent into the manifold
MixManMash
14:44:53 06/09/09
Any chance PCV valves are bad, installed incorrectly, etc?
blackomega
14:47:42 06/09/09
For starter's, on these cars the PCV valve threads into the
MixManMash
14:58:38 06/09/09
2nd. 50-50 motor or turbos from what I've seen. (n/m)
yobobrox
00:31:14 06/10/09
Turbos have only 110 miles on them
blackomega
13:49:50 06/09/09
running oil restricotrs to your GT28RS'?
JustinSCZ32
17:33:52 06/09/09
Very good point you made! I forgot about that. (n/m)
MixManMash
18:05:16 06/09/09
i ended up blowing a seal on my pass. side turbo FYI
JustinSCZ32
18:10:16 06/09/09
So I assume that the oil restrictors came with the kit??
blackomega
18:20:56 06/09/09
i got over a year of use with my turdblows (n/m)
JustinSCZ32
18:43:19 06/09/09
without the oil restrictors?
blackomega
18:49:49 06/09/09
yea, and daily drove..put around 15k on everything
JustinSCZ32
21:24:55 06/09/09
I believe it's the Z1 kit that you did purchase. If that's
MixManMash
22:19:50 06/09/09
When turbo seals fail, does the oil pass directly...
BeachZ
08:59:14 06/10/09
Depends which seal and how it fails.
Woody75 (Denver)
10:18:27 06/10/09
Thanks to everyone for feedback.
blackomega
18:21:38 06/09/09
Well, let us know if any of the information was useful.
MixManMash
22:25:20 06/09/09
