TwinTurbo.NET: Nissan 300ZX forum - Boosting to 19 psi was probably not a good idea
Subject Boosting to 19 psi was probably not a good idea
Posted by ThunderZ on June 05, 2009 at 9:00 PM
  This message has been viewed 119 times.
In Reply To 3 days and 100 miles later: problems posted by blackomega on June 05, 2009 at 03:56 PM
Message on a 1st drive. The hose connections and gaskets didn't have a chance to "glue" themselves in place, so you might have just simply knocked a turbo coupler loose.
Does it sound like a wooooo when you boost? If so, you most likely knocked loose the coupler that goes from the turbo to the tube on the pressure side. You can tighten both sides easily. Just go over those types of connections 1st before doing anything crazy like pulling the motor again.
