TwinTurbo.NET: Nissan 300ZX forum - the gasket can not be slid in
Subject the gasket can not be slid in
Posted by gt300zxtt on June 05, 2009 at 6:00 PM
  This message has been viewed 101 times.
In Reply To And if I can tighten bolts I can slide in a gasket? posted by blackomega on June 05, 2009 at 05:37 PM
Message if the gasket has to be replaced, then you have to remove the manifold as the gasket goes over the studs just as the manifold does. in the case where you tighten the nuts, we are hoping that the gasket has not been destroyed and there is just a gap between the manifold and the gasket or the head and the gasket.
exhaust mani gasket
here you can see that the manifold
