TwinTurbo.NET: Nissan 300ZX forum - Re: Re: oil would be bluish gray...
revolutionary
on June 05, 2009 at 4:30 PM
posted by blackomega
on June 05, 2009 at 04:27 PM
If its ball bearing turbos and you didnt use the right oil lines that can be a cause of smoke.
3 days and 100 miles later: problems
blackomega
15:56:37 06/05/09
details i want to clarify
blackomega
16:09:21 06/05/09
gt300zxtt
16:21:11 06/05/09
blackomega
16:27:27 06/05/09
Re: Re: oil would be bluish gray... -
revolutionary
16:30:57 06/05/09
the smoke is from condensation
gt300zxtt
16:35:26 06/05/09
Do you have stock pistons? Check oil pan
icsamerica
21:10:50 06/07/09
Stock pistons, 93 octane, only one run at 1.3 bar
blackomega
11:41:50 06/09/09
first locate the leak
gt300zxtt
16:32:33 06/05/09
"in this case, i would try to get a wrench on the manifold "
blackomega
16:37:23 06/05/09
do you have factory heat shields in place? (n/m)
gt300zxtt
16:55:51 06/05/09
ditched them during the install (n/m)
blackomega
16:59:00 06/05/09
that will help tremendously
gt300zxtt
17:04:07 06/05/09
And if I can tighten bolts I can slide in a gasket?
blackomega
17:37:18 06/05/09
the gasket can not be slid in
gt300zxtt
18:00:01 06/05/09
What do you think my chances are
blackomega
18:18:32 06/05/09
theres no telling about the gasket's chances
gt300zxtt
19:24:05 06/05/09
I'm not sure if the shop will warranty or not.
blackomega
13:32:29 06/06/09
about the condensation
gt300zxtt
21:21:58 06/05/09
im not so sure...
blackomega
08:50:59 06/06/09
Re: about the condensation
blackomega
13:31:21 06/06/09
Boosting to 19 psi was probably not a good idea
ThunderZ
21:00:58 06/05/09
hes explaining exhaust leak not intake leak.
gt300zxtt
21:14:46 06/05/09
Re: 3 days and 100 miles later: problems
WazTTed
22:04:26 06/06/09
