TwinTurbo.NET: Nissan 300ZX forum - Right. But you'll notice it in Mode II check>>
Subject Right. But you'll notice it in Mode II check>>
Posted by Zarcasm(Hfd, CT) on March 25, 2009 at 10:02 PM
  This message has been viewed 393 times.
In Reply To The CEL will not come on for a slow O2 sensor>> posted by ZUL8TR on March 25, 2009 at 04:35 PM
Message I didn't check the actual voltages from the old O2 sensor. I watched the flashes and the RHS was no where near 5 CEL blinks per 10 seconds, in fact the CEL stayed on completely. All tests were performed at 2000 rpm. The new O2 sensor is OEM. I think OEM is Bosch, right? The new O2 flashes much less than 5/10 seconds whereas the RHS O2 sensor is completely normal. All RHS spark plugs are charcoal black. Now I'm suspecting maybe an air leak on one side of the engine leading to imbalanced airflow? The manual calls for pinching off PCV flow and/or disconnecting the canister. It's taken me a while to locate the PCV valves and looks like a real pain to pinch them off. Any other thoughts?
