TwinTurbo.NET: Nissan 300ZX forum - The CEL will not come on for a slow O2 sensor>>
Subject The CEL will not come on for a slow O2 sensor>>
Posted by ZUL8TR on March 25, 2009 at 4:35 PM
  This message has been viewed 351 times.
In Reply To Brand new O2 sensor slow response posted by Zarcasm(Hfd, CT) on March 23, 2009 at 11:14 PM
Message It will come on if the sensor completly fails.
Check the O2 sensors for actual voltage readings at the connector with the engine running at 2000. With a digital VOM you can see the high and low readings volt. Ideal volt readings are 0v low and 1 v high. Good values are 0.1v to 0.25 low and 0.75 to 0.9v high. The closer the low and high readings are to about 0.5v average the more worn the O2. So you can have the O2 give 5 CEL blinks minimum per 10 sec and still have poor performing O2s due to poor volt readings.
What brand O2s are you using, are they OEM units or Bosch or other?
ZUL8TR in Orlando,FL
