TwinTurbo.NET: Nissan 300ZX forum - Re: new upper links
Subject Re: new upper links
Posted by forge on September 10, 2008 at 3:37 PM
  This message has been viewed 152 times.
In Reply To I just bought new upper links and new king pins. posted by Spddracer on September 07, 2008 at 06:05 PM
Message The parts were all factory Nissan, hence my confusion. However, I seemed to have solved the problem by using a .005" shim between the lower bearing and the kingpin. Apparently Nissan changed from NTN (factory bearing) to NSK (new bearing) at some point; the NSK bearing has slightly different chamfering on the shoulders, and that caused the play. At least, that is the only explanation I can come up with. Looking back on the whole situation, I should have just bought new links and called it done. Thanks for you input :)
