TwinTurbo.NET: Nissan 300ZX forum - I don't think the ABS is your problem
Subject I don't think the ABS is your problem
Posted by aliaZ on August 27, 2008 at 10:56 PM
  This message has been viewed 129 times.
In Reply To abs locking up cant find check connector location posted by 600ZXR on August 27, 2008 at 10:34 PM
Message Do you have an ABS light on?
ABS is a passive system...it doesn't apply the brakes.
When your brakes warm up, the brake fluid expands, and must be able to bleed back into the master cylinder. Something is preventing this from happening. If the pushrod on your booster is adjusted incorrectly, the master cylinder piston may not return all the way, which would block the fluid from returning to the master cylinder.
