TwinTurbo.NET: Nissan 300ZX forum - please help...overheating issue.....need help
Subject please help...overheating issue.....need help
Posted by Vonblake83 on August 27, 2008 at 12:48 AM
  This message has been viewed 143 times.
Message Ok so my car started to overheat about a week ago and this is where my problem started. I replaced the thermostat first and the car still was heating up... so I then replaced the radiator... The car was not heating up for the last two day so I thought I fixed it.. Well tonight i drove to my folks house for dinner and the car shot up to 3/4... and a little hotter...... Ive checked the waterpump before andit does not leak or wobble and is really tight...so after searching the forum I didnt see anything that would indicate the water pump being bad.... When I got to my parents I luckily had another new clutchfan so I through it on there.. on my drive home the temp went back up after a couple of miles..
so my question is.. I have replaced the radiator, thermostat and clutch fan...the only thing left is the waterpump which is showing no signs of being bad...leaking or wobbleing.....
what else should I check or should I just replace the waterpump.....or should I have a mechanic check it out and spend the money to be sure?
Also the car still runs perfect and has the same power as before.....but could I have a blown head gasket....there is no water in the oil..... Im running out of Ideas here,,,please help...thanks
