TwinTurbo.NET: Nissan 300ZX forum - Re: need help, just replaced the clutch slave cylinder.
Subject Re: need help, just replaced the clutch slave cylinder.
Posted by ZUL8TR on August 26, 2008 at 5:43 AM
  This message has been viewed 115 times.
In Reply To need help, just replaced the clutch slave cylinder. posted by irfan5911 on August 25, 2008 at 11:02 PM
Message Did you bleed the system at both points at slave cylindere and the under hood passanger side location? This usually requires several tries to get all the air out.
Is the slave push rod properly lined up with the clutch fork. There is a dedent in the clutch fork that the slave push rod fits into for proper alignment. There should also be a small amount of grease with Molydisulfide in it placed on the tip of the slave push rod.
ZUL8TR in Orlando,FL
