TwinTurbo.NET: Nissan 300ZX forum - EGR delete question...
Subject EGR delete question...
Posted by Obeeone on August 25, 2008 at 4:16 PM
  This message has been viewed 221 times.
Message I have a boost leak near the rear of my engine that I cannot find, through research it sounds like the egr problem most people have.
My question is would it work to buy two sets of intake manifold block off plates to delete the egr without pulling the intake plenum. My idea is to use one set on the plenum side and the other set on the egr tube side with a solid gasket material to cover the holes on the tubes. I am just looking to eliminate any possible boost leaks from the egr a little more simply. I am not looking to pull the plenum until I lose some injectors and upgrade to the newer style. Thanks for any advice.
