TwinTurbo.NET: Nissan 300ZX forum - Re: huh?
Subject Re: huh?
Posted by priviello1 on August 24, 2008 at 10:07 PM
  This message has been viewed 122 times.
In Reply To huh? posted by aliaZ on August 24, 2008 at 09:19 PM
Message Turbos spooled yesterday but all boost was escaping from a hole in the intercooler. Fixed the intercooler today and now the boost system will hold air, but turbos will not spool or do anything. The system isn't air tight and leaks down very slowly. I need to make it clear so viewers can better understand the situation...
Turbos worked for 400 miles yesterday on the road, factory gauge showed they were very healthy. Went for a 2 mile drive this morning pretty much babying the car and the turbos were spooling. If I had run the piss out of it on the drive I would be worried they overheated and seized up, but since thats not the case I do not believe it is the turbos themselves. I was in the engine bay all day fixing leaks I could find.
Not knowing removing the master cyl would expose the two leaking hose clamps I needed to get to, I pulled out the factory metal pipe on the drivers side that runs just below the wire harness that goes to the fuse box up front. I'm thinking in the process of removing that, I have pulled another hose out that I have no idea how to get to or even where it is.
If the turbos were going to decide to seize I would think it would have happened after the 400 mile drive last night and not the two mile trip this morning with me not getting up on the car at all.
