TwinTurbo.NET: Nissan 300ZX forum - No reason why it shouldn't work. Just keep in mind
Subject No reason why it shouldn't work. Just keep in mind
Posted by kkrofft (OH) on August 24, 2008 at 12:50 PM
  This message has been viewed 75 times.
In Reply To clutch slave prob posted by danvan on August 24, 2008 at 11:00 AM
Message that the smaller bore means less mechanical advantage so a slightly stiffer pedal. My only fear would be that with the smaller bore the slave will travel farther for the same amount of pedal travel. Be sure you are not bottoming out the release fork or it will likely fail at some point. Adjust the pedal to get a good release with no binding and you will be fine.
KKrofft
