TwinTurbo.NET: Nissan 300ZX forum - Re: Speed sensor replacement
Neflyte
on August 24, 2008 at 9:46 AM
posted by Adrian (Dallas)
on August 23, 2008 at 07:23 PM
release the sensor first and then pull the cable forward so you can reach the conector, put some boards in the rear wheel too to make more room, i use the same boards in mine, don't forget the ground wire, good luck!!!
Adrian (Dallas)
19:23:19 08/23/08
nice ramps, could've made em longer to get the back up too (n/m)
550HPTT
19:55:51 08/23/08
Re: Speed sensor replacement -
Neflyte
09:46:05 08/24/08
the speed sensor has that funky connector on it
spyhunterTT(nj)
11:09:04 08/24/08
Re: the speed sensor has that funky connector on it
Adrian (Dallas)
20:00:29 08/25/08
its definately easy, just unscrew the screw and pull
itsghoZt
19:31:39 08/25/08
