TwinTurbo.NET: Nissan 300ZX forum - Only use NGK plugs in our cars. Every other plug will do
Subject Only use NGK plugs in our cars. Every other plug will do
Posted by 5280Z_nightstalker on August 23, 2008 at 3:28 PM
  This message has been viewed 90 times.
In Reply To Problems worsen after new plugs installed posted by Adam_K89 on August 23, 2008 at 02:33 PM
Message as you said and make the car run like poo. First do you have your splash sheild attached to the pop charger? The splash sheild must be attached I hear this can cause the car to run poor. Next make sure you are firing on all cylinders and make sure all injectors OHM out between 10-14ohms. I would also run a ECU self Diagnostic and see if you have any error codes that are showing up. Just take a minute collect yourself and try to trace the problem.
Good luck.
