TwinTurbo.NET: Nissan 300ZX forum - I don't think CHT's would even be possible on the Z
Subject I don't think CHT's would even be possible on the Z
Posted by 550HPTT on August 22, 2008 at 4:46 PM
  This message has been viewed 139 times.
In Reply To Re: The maximum reading from each probe isn't the issue. posted by Bezza on August 22, 2008 at 02:49 PM
Message Most install under the spark plug in place of the spark plug washer. You would also need one for each cylinder unlike needing on one per bank for EGT's. I could not understand your first sentence but it sounds like the fire you had on the EGT sensors were beyond there range. Try to heat them both evenly to a lower temp and see if they both read the same. It wouldn't matter if one reads a higher maximum temp just as long as they read the same at any given temp below there max
I do not fear what the future holds for me, I am not afraid to die.
