TwinTurbo.NET: Nissan 300ZX forum - Not neccesary to change the fuel rail
Subject Not neccesary to change the fuel rail
Posted by Tektrader69 on August 21, 2008 at 8:05 PM
  This message has been viewed 372 times.
In Reply To Re: Re: Sard 850cc injectors and O-Rings posted by WazTTed on August 21, 2008 at 06:15 PM
Message All it does is gives people a warm fuzzy feeling cause they have a nice alloy extrusion u can see.
The bore size on the 300 degree rail is much the same size as the stock rail, and the border isnt much different. So why even bother
The other reason you should stick to stock ( unless you have BIG power 350-400kw) is that the fuel rail is thermally islolated from the lower plenum. AFAIK both those other rails are not meaning they run hotter.
Running hotter fuel should be avoided.
