TwinTurbo.NET: Nissan 300ZX forum - to pull the lower plenum to get to the knock sensor,
gt300zxtt
on August 21, 2008 at 10:48 AM
looking for pic of det sensor in stock location
posted by BOOZT_JUNKIE
on August 21, 2008 at 10:44 AM
then yes. the top idler pulley is attached to the lower plenum, so in order to remove the lower plenum, the timing belt must be removed.
BOOZT_JUNKIE
10:44:27 08/21/08
to pull the lower plenum to get to the knock sensor, -
gt300zxtt
10:48:44 08/21/08
notice the bolt hole on the rear pass side as noted in your
gt300zxtt
10:51:54 08/21/08
Misleading location description, IMO. Between the two banks
10:55:23 08/21/08
you could even add: slightly offset to the pass side
gt300zxtt
10:58:09 08/21/08
Or...
fantomZ(OH)
11:09:29 08/21/08
Or Just use TT XTZ's "Where is it?" page
ZXRider(SoCal)
12:35:09 08/21/08
Here is a pic of it in the stock location
doug8867
11:10:38 08/21/08
awesome, thanks everyone!
BOOZT_JUNKIE
12:07:33 08/21/08
Depends on how you plan to access it - it can be done from
12:15:24 08/21/08
