TwinTurbo.NET: Nissan 300ZX forum - Two of the wires are for the heating element.
Subject Two of the wires are for the heating element.
Posted by kkrofft (OH) on August 21, 2008 at 6:56 AM
  This message has been viewed 107 times.
In Reply To Bosch 02 Sensors, wiring and resistors posted by z-spott[HI] on August 21, 2008 at 02:40 AM
Message You need to tell us how you have it wired and where you are measuring the voltage. For the most part all common narrowband O2 sensors are functionally similar. Once warmed up the heater circuit shuts off and you should be measuring
between the white wire and ground. Also you must use an analog meter as typical digital meters do not respond fast enough to see the switching.
If the 320Mv is correct then you probably have something causing the lean condition. Vacuum leak etc...
There is no reason I can think of why I would EVER add a resistor to that circuit and expect it to work.
KKrofft
