TwinTurbo.NET: Nissan 300ZX forum - Re: starter current draw
Subject Re: starter current draw
Posted by 90coupeconversion on August 21, 2008 at 12:47 AM
  This message has been viewed 591 times.
In Reply To starter current draw posted by BIGDOUG on August 20, 2008 at 03:07 PM
Message When checking a vehicle with starting issues,(failing starter) the acceptable current draw from a starter is 250A. I have tested alot of starters, an electrically "good" starter will typically draw 50-180A. When testing an electrically "bad" starter (one that stuggles to turn over) your amp draw goes 250A+ . I would say that you would be safe using a 250A fuse. The only time it should blow, is when the starter starts to draw too much amperage.
