TwinTurbo.NET: Nissan 300ZX forum - This is what we use on aircraft
Subject This is what we use on aircraft
Posted by DAYTONAZ on August 20, 2008 at 7:46 PM
  This message has been viewed 190 times.
In Reply To Not much in search. What lube do you use for installing>>>>> posted by ZUL8TR on August 20, 2008 at 02:25 PM
Message This is just some random website but the picture is correct.
[ http://www.marcorubber.com/o_lube.htm ]
Parker lube, It's better than vaseline if you're going to be doing a lot of o-ring/seal type work. This is also a much better choice when installing shaft seals as it stays put. Motor oil and vaseline will wick away from the sealing surface of seals over time such as when an engine is being built.
