TwinTurbo.NET: Nissan 300ZX forum - Follow up to car will not stop running
Subject Follow up to car will not stop running
Posted by jlc3 on August 20, 2008 at 7:29 PM
Message I have a 91 300Z TwinTurbo. The fuel pump fusible link blew while the car was being driven. The cause was the wire from the fusible link was shorted to the body. Repaired the wire and insulated the body wear point. When I turn the key to ON all the dash lights come as normal. While troubleshooting the short problem the F25 to E12 connector was disconnected. We forgot to reconnect it and tried to start the car twice. We reconnected the connectors. When we started the car all the dash lights go out as normal. The car starts and runs fine. When I turn the engine OFF all the dash lights come but are very dim and the engine continues to run. I have to disconnect the battery or pull the ECCS relay to get it to stop. There were no codes or problems before the short. More troubleshooting shows 12 volts to eccm pin 16 when ignition switch is turned to ON or START. When the ignition switch is turned OFF (and key removed) there is 5 volts being supplied to eccm pin 16. This is when the dash lights are very dim and the engine continues to run. Opening the circuit to eccm pin 16 shuts everything down as it should. The manual indicates that Pin 16 is the E.C.U. power source and that it self-shuts off a few second after turning the ignition switch OFF. It appears that voltage is leaking through the shutoff circuit in the E.C.U.. Any suggestions on where I can get a stock 91 300Z TwinTurbo E.C.U. repaired?
