TwinTurbo.NET: Nissan 300ZX forum - Help Car Dies and erratic Idle w/ some other issues
Subject Help Car Dies and erratic Idle w/ some other issues
Posted by Justin3z on August 19, 2008 at 8:25 PM
  This message has been viewed 181 times.
Message Ok I have a problem. My car when I start it up it will shake and jerk with extremely erratic idle. Until it eventually dies. I can start the car back up, but once I start it it will die unless I give it alot of gas and when I give it gas it feels like it catches because i can press the gas hard and it wont respond for about 5 seconds then finally stops and rises. Also, when driving under normal conditions the car goes into saftey boost. Even if I have not hit boost. I can drive it for 10 min until it warms up give it some gas and the boost sticks at safetly boost until I turn the car off and start it back up. Then about 30 min later it does it again. Another thing I have noticed is when I hit boost with the AC on there is a loud squeak or squeal right after I let off of the gas.
Ne help would be really appreciated.
Nismo 740s with Speciality Z rail
2.5 exhaust from the down pipes back.
JWT Pop
Greedy Boost Controller
ERG eliminated
short throw shifter
Z1 intercoolers
Ashspec ECU Upgrade
lightened flywheel and stage 5 clutch
__________________
