TwinTurbo.NET: Nissan 300ZX forum - Likely the odometer needs to be removed and cleaned.
Subject Likely the odometer needs to be removed and cleaned.
Posted by doug8867 on August 19, 2008 at 11:50 AM
  This message has been viewed 107 times.
In Reply To 1990 TT Odometer issues posted by Nismoniac on August 18, 2008 at 09:58 PM
Message Mine had the same problem and removing it and spraying the gears with
electrical contact cleaner flushed out a bunch of black gunk. Then the gears
didn't get stuck any longer and it's worked fine for a couple years now.
There was a writeup on here by a Swiss guy in the FAQ > AutoFAQ section
but I see the link is not working anymore. :-( You might try Google and search
"z32 odometer fix", as someone else may have copied the info. If you can't
find it email me and I'll see if I can dig out any printouts I may have used if I
still have them. Then I could scan them and email them to you.
