TwinTurbo.NET: Nissan 300ZX forum - Re: Grinding noise while holding down the clutch
Subject Re: Grinding noise while holding down the clutch
Posted by 90coupeconversion on August 19, 2008 at 12:06 AM
  This message has been viewed 127 times.
In Reply To Grinding noise while holding down the clutch posted by Heavyarms2050 on August 18, 2008 at 01:50 PM
Message I have seen before where 2 seperate vehicles(300GT, and 85 300ZX) have had the free play on the pedal adjusted so light that when I pushed the clutch in with Hercules force, they would both make a scaping noise, and would not go into gear. In a nutshell, the throw out bering is pushing in too much and it sandwiches the the pressure plate fingers into the hub of the disc. Both vehicles were fixed by adding a little free play to the clutch pedal. You may be only experiencing it once in a while due to you not Slamming the pedal all the way down.
