TwinTurbo.NET: Nissan 300ZX forum - Cylinder Questions
Subject Cylinder Questions
Posted by KKx on August 18, 2008 at 7:27 AM
  This message has been viewed 156 times.
Message I seem to have lost the #4 cylinder in my car and am stumped.
I've done a compression check and it is right at 150psi. The coil pack is ohming out fine. I've switched it and the spark plug just to see if that would change anything and it didn't. When I pulled the spark plug it was very dry and has turned the whitish color. I am receiving the voltage signal thru the connector. What else should I look at? Valve sticking? Would a leak down test show more at this point? How bad do you guys think this could be? TIA...
