TwinTurbo.NET: Nissan 300ZX forum - Less vacuum = lower compression
Subject Less vacuum = lower compression
Posted by BobbyT on August 17, 2008 at 11:35 PM
  This message has been viewed 97 times.
In Reply To Shaft play in turbo posted by inf on August 16, 2008 at 06:35 PM
Message That means pistons rings, or valve seals.
Vacuum is the pull from the descending piston through the intake valves measured at the plenum (while the exhaust valves are closed)...turbos don't enter the equation.
