TwinTurbo.NET: Nissan 300ZX forum - Very good chance your connectors are corroded which is
Subject Very good chance your connectors are corroded which is
Posted by Audioquest on August 17, 2008 at 2:24 PM
  This message has been viewed 81 times.
In Reply To Need help with a possible injector problem...kinda long posted by bt300z32 on August 16, 2008 at 08:35 PM
Message really common as they are crap. Spend some time diagnosing the problem before you start taking the plenum off.
Pull the CAS, PTU, MAF, Coolant Temp Sensor, TPS, AAC, FICD, & Air Regulator connectors and check for corrosion. With your description of wiggling the connectors and it gets better points to this could be at least a part of your problem.
Scrape all you can off, then use good quality spray contact cleaner and finally dielectric grease to protect them.
When the injector connectors are off, test them with a multimeter. They should be 10 to 14 ohms to be in factory spec.
If all of this doesn't do it, you will need to test the rest of the components.
Spending time to get the basics right usually corrects most issues like this
