TwinTurbo.NET: Nissan 300ZX forum - Please post this question in the Tech section but here is
Subject Please post this question in the Tech section but here is
Posted by 5280Z_nightstalker on August 17, 2008 at 12:21 AM
  This message has been viewed 129 times.
In Reply To Need help with a possible injector problem...kinda long posted by bt300z32 on August 16, 2008 at 08:35 PM
Message what you need to do.
injectors
Also if you having injector problems then a 300 degree fuel rail is not going to fix anything. You have to buy new injectors and expect to spend some money then. If you want to see if it is just connectors hook up a multimeter on volts and have a buddy turn the car over (pull fuel fuse first) while you have the multimeter plugged into both ends of the harness, it should read 12volts.
Good luck
