TwinTurbo.NET: Nissan 300ZX forum - Lower vacuum?
Subject Lower vacuum?
Posted by yobobrox on August 16, 2008 at 6:43 PM
  This message has been viewed 121 times.
In Reply To Shaft play in turbo posted by inf on August 16, 2008 at 06:35 PM
Message Are you sure that's what you meant to say? We're talking about the
negative side of the boost gauge, and you're saying that your gauge used
to go more negative than it does now?
If you're worried about the turbos: you're not going to have a seized turbo
and not know it. You won't be boosting (stock z). And if the shaft has play,
(I'm assuming you have checked it) on what axis is it loose? There should
be a slight amount of in and out movement, but none (or very little) from
side to side.
