TwinTurbo.NET: Nissan 300ZX forum - Re: Only torque the bolts to 30 lbs MAX or the inserts will
JSD-ZX
on August 14, 2008 at 9:55 AM
posted by Audioquest
on August 14, 2008 at 07:54 AM
Live and learn, it makes perfect sense now. When I took the clutch off the flywheel there wasn't any sign of wear, I don't even know why or how it went in gear. Life saver bro, thanks
Clutch Issue remains, different problems!!!
JSD-ZX
22:01:56 08/12/08
The way you describe being able to go into gears when it is
5280Z_nightstalker
00:53:59 08/13/08
It can only be one of 3 things:
Audioquest
08:51:51 08/13/08
Re: It can only be one of 3 things:
JSD-ZX
10:29:47 08/13/08
When you adjust the rod, only turn it up enough so
Audioquest
11:06:48 08/13/08
Re: When you adjust the rod, only turn it up enough so
JSD-ZX
17:52:52 08/13/08
Well, when you put the PP on, it has to be sucked down with
Audioquest
21:14:25 08/13/08
Re: Well, when you put the PP on, it has to be sucked down w
JSD-ZX
04:29:07 08/14/08
Audioquest
07:54:32 08/14/08
Re: Only torque the bolts to 30 lbs MAX or the inserts will -
JSD-ZX
09:55:11 08/14/08
