TwinTurbo.NET: Nissan 300ZX forum - Only torque the bolts to 30 lbs MAX or the inserts will
Subject Only torque the bolts to 30 lbs MAX or the inserts will
Posted by Audioquest on August 14, 2008 at 7:54 AM
  This message has been viewed 98 times.
In Reply To Re: Well, when you put the PP on, it has to be sucked down w posted by JSD-ZX on August 14, 2008 at 04:29 AM
Message strip out. Tighten them down in an X pattern like you would with a wheel so it's seated evenly and flat. Make sure those dowels don't hang up in the holes either.
I am amazed your car moved at all if the PP wasn't tightened flat against the RPS flywheel as there would be virtually no clamping pressure.
Glad to hear you found the problem.
