TwinTurbo.NET: Nissan 300ZX forum - Re: Well, when you put the PP on, it has to be sucked down w
JSD-ZX
on August 14, 2008 at 4:29 AM
Well, when you put the PP on, it has to be sucked down with
posted by Audioquest
on August 13, 2008 at 09:14 PM
The TO bearing is straight. I didn't know the PP had to be sung in. It seem like the Rps aluminum would strip thats why I never put real pressure on it. That makes perfect sense I will make it happen in the morning thanks Audioquest.
Clutch Issue remains, different problems!!!
JSD-ZX
22:01:56 08/12/08
The way you describe being able to go into gears when it is
5280Z_nightstalker
00:53:59 08/13/08
It can only be one of 3 things:
Audioquest
08:51:51 08/13/08
Re: It can only be one of 3 things:
JSD-ZX
10:29:47 08/13/08
When you adjust the rod, only turn it up enough so
Audioquest
11:06:48 08/13/08
Re: When you adjust the rod, only turn it up enough so
JSD-ZX
17:52:52 08/13/08
Audioquest
21:14:25 08/13/08
Re: Well, when you put the PP on, it has to be sucked down w -
JSD-ZX
04:29:07 08/14/08
Only torque the bolts to 30 lbs MAX or the inserts will
Audioquest
07:54:32 08/14/08
Re: Only torque the bolts to 30 lbs MAX or the inserts will
JSD-ZX
09:55:11 08/14/08
