TwinTurbo.NET: Nissan 300ZX forum - Well, when you put the PP on, it has to be sucked down with
Subject Well, when you put the PP on, it has to be sucked down with
Posted by Audioquest on August 13, 2008 at 9:14 PM
  This message has been viewed 69 times.
In Reply To Re: When you adjust the rod, only turn it up enough so posted by JSD-ZX on August 13, 2008 at 05:52 PM
Message the bolts, that's what gives it the clamping force, just like when the pedal is up. The disc really can't go on backwards either. Is your TO bearing lever straight? Even a little bent will result in not as much release
