TwinTurbo.NET: Nissan 300ZX forum - run the codes.....then
Subject run the codes.....then
Posted by Firstgearlaunch(Atlanta) on August 13, 2008 at 8:28 PM
  This message has been viewed 429 times.
In Reply To Really need an insight on my TURBO BOOST issue posted by Ketch on August 13, 2008 at 04:45 PM
Message check the codes first, ill take a guess that its the detonation sensor or harness , connector, this can send a signal to your ecu for safety boost ( anywhere from 5-7psi tops) .. if i wiggle my burned up connector and wires on the det sensor ..my safety boost disappears. Im going to fix it this weekend,but until then your ecu will revert to a rich program ,retard the ignition , and limit boost. Dont bypass the det sensor...there is a faq on this , but i suggest dont do it. esp with todays shitty ethenol gas mix.
