TwinTurbo.NET: Nissan 300ZX forum - Re: When you adjust the rod, only turn it up enough so
Subject Re: When you adjust the rod, only turn it up enough so
Posted by JSD-ZX on August 13, 2008 at 5:52 PM
  This message has been viewed 76 times.
In Reply To When you adjust the rod, only turn it up enough so posted by Audioquest on August 13, 2008 at 11:06 AM
Message I do have all the air out, and i adjusted the pedals just like you suggested.
I already dropped the transmission, I'm pretty sure its a pressure plate deal. I had the oreintation correct, but I think I was sold a mislabled part. When I line the clutch with the dowel pins on the flywheel, the clutch does not mate up flush with the flywheel. I do understand that the clutch can only be put on one way, and basically I have a 3 mm gab in between the clutch and flywheel. Its almost like the pressure plate is too thick.
I'm trying to source a replacement, but that is all i can think of because the TO bearing looks correct and the clutch fork is not bent.
