TwinTurbo.NET: Nissan 300ZX forum - Clutch Issue remains, different problems!!!
Subject Clutch Issue remains, different problems!!!
Posted by JSD-ZX on August 12, 2008 at 10:01 PM
  This message has been viewed 116 times.
Initially, I was having a reverse issue, that has been ironed out, but the car will not go into gear.
I have bleed all the air out, and I have adjusted the pedals and rod. All I can figure is that I'm having a problem internally. I would drop the tranny but the following is puzzling me.
On jack stands, I can put the car in 1st, 2nd and reverse. The wheels would spin as they should. However, when the car is placed on the ground and I push the clutch pedal in I cannot put the car in 1st or reverse.
Why would the car be able to go into gear on jack stands but not on the ground? I also removed the reverse lockout mechanism, would this cause an issue going into 1st?
