TwinTurbo.NET: Nissan 300ZX forum - They should be gapped at 0.030 and shouldn't blow out at
Subject They should be gapped at 0.030 and shouldn't blow out at
Posted by phillyz on August 12, 2008 at 4:58 PM
  This message has been viewed 183 times.
In Reply To what would cause my Z to "Break up" under full boost posted by volcomstone550 on August 12, 2008 at 04:15 PM
Message 18 psi. Check the gap. If that's fine, you may have a coil pack going bad. Do a drop down test if you get to that point. You do that by disconnecting the connection to the coil pack while the car is idling. When you pull the connection, the idle should drop and the engine should fumble and then return to normal when you plug it back in. If you pull a connection and there is no change, you could have a problem in that cylinder with either the coil pack or injector.
"All I heard was all of this air whooshing around behind me and then you blew by me, just when I thought I had you."
- Disgruntled Mustang GT Owner :-(
"I use to love speed when I was younger, but now it just scares me."
- My father in-law after his first ride in my Z32 :-0
