TwinTurbo.NET: Nissan 300ZX forum - A testlight would be highly recommended to trouble shoot
Subject A testlight would be highly recommended to trouble shoot
Posted by 550HPTT on August 12, 2008 at 4:44 PM
  This message has been viewed 83 times.
In Reply To hooked up right but only works when.. posted by Mike87T on August 12, 2008 at 02:37 PM
Message your problem. You may have a burnt fuse on the either of the two power wires. Try with the key off to see if the radio will come on when you connect both radio wires to the (Z) yellow wire. If it doesn't come on then the yellow is dead. If it does then hook both radio wires to the (Z) blue wire and turn on the ignition to see if the radio comes on. If it doesn't then the blue is dead. Or you can save all the hassle and get a 3$ test light from autozone
I do not fear what the future holds for me, I am not afraid to die.
