TwinTurbo.NET: Nissan 300ZX forum - Worn stock tension rod bushings can cause this. Are yours
MobZ
on August 12, 2008 at 12:36 PM
How to DIY realign my tires
posted by Heavyarms2050
on August 11, 2008 at 03:56 PM
leaking? If so you can either buy new adjustables, replace with new stock TRs, or install the new type Energy Suspension bushings in your existing TRs.
Heavyarms2050
15:56:51 08/11/08
Your wear could be due to camber and not alignment
550HPTT
18:14:16 08/11/08
to be honest, the wheel looks perfecly perpendicular to the
Heavyarms2050
18:29:52 08/11/08
You can't adjust the camber with stock front suspension
550HPTT
18:39:40 08/11/08
if i can't adjust the camber, then what can i do?
Heavyarms2050
19:00:43 08/11/08
Aftermarket adjustable camber arms SPL, Powertrix etc.
550HPTT
19:07:31 08/11/08
You probably want to have it checked professionally before
FuerGrissa
20:06:07 08/11/08
T_T god why does fixing minor things cost so much (n/m)
Heavyarms2050
22:10:18 08/11/08
God gave us the Z, this is the devil's way of getting even (n/m)
FuerGrissa
22:29:42 08/11/08
As FuerGrissa mentioned there is the 300Degree kit that may
550HPTT
07:20:49 08/12/08
CHECK your camber with a plumb-bob, not your eye:
zellamay
09:48:50 08/12/08
Worn stock tension rod bushings can cause this. Are yours -
MobZ
12:36:31 08/12/08
Or install NISMO tension rod bushing (n/m)
Fast300
13:49:14 08/12/08
